  • Configure manual-area in both home and remote area.
  • Configure the Shortest Path Bridging MAC (SPBM) instance and backbone VLANs (B-VLAN) manually.
  • Configure the nickname in both home and remote area manually.
Perform this procedure to enable remote IS-IS router configuration on the switch, globally.
    enable
    configure terminal
  2. Enable IS-IS router remote configuration:
    router isis remote [enable]
Enabling IS-IS router remote configuration globally:
Switch:1>enable
Switch:1#configure terminal
Switch:1(config)#router isis remote enable
What to do next
To verify the configuration, see Display IS-IS Remote Area Configuration.
The following table defines parameters for the router isis remote command.
Variable Value
enable
Enables router IS-IS remote configuration globally on the switch.
